Windows 7...to install or not to
Discussion in 'Computer Software & Operating Systems' started by gino_76ph, Feb 4, 2009.
  1. gino_76ph
    gino_76ph
    Aug 10, 2007
    574
    i currently have Vista Home premium and i am tempted to install Windows 7. is it safe to install the beta release or shall i waitfor the RC1 version? any bugs or issues so far?
  2. sunnybacon
    sunnybacon
    Mar 6, 2008
    3,267
    Leicester
    +433
    If you're not comfortable with installing over the top, you can dual-boot it, check out the threads in this forum :smashin:
  3. Faust
    Faust
    Dec 21, 2002
    3,525
    UK
    +759
    I installed W7 on my backup PC over the top Vista - I changed back to Vista a few weeks later as I couldn't see why a Vista user would want W7. It looks very similar works very similar but uses a tad less resources. Apart from that for the average user it's Vista with a different name and as I love Vista then hey what's the point. I think W7 is aimed at XP users who have refused to migrate to Vista due to the wholly uncalled for bad press.
    One thing I would warn of - when trying to go back to Vista you will have to do a clean install. The Vista install disk warned I could not upgrade to an older version of Windows i.e. W7 is newer than Vista so make sure you have a backup image or else you will have to do a clean install.
  4. treacle
    treacle
    May 17, 2006
    598
    +16
    Its a little foolish to install a Beta over a current system, its easy enough to dual boot,
    Your current system for everyday working, Beta for experimenting.
    I find 7 is an extremely fine system, for a Beta its probably the best that M/S has ever released.
    This will outperform Vista, in nearly every way, can't wait for the finished product.:smashin:
  5. SkyCaptain
    SkyCaptain
    Aug 4, 2007
    506
    28
    +38
    just to jump on the thread, ive got release 7000 of the 64bit version and 7022 of the 32bit. How "complete" is the earlier version? Id rather try that as ive got 6 megs of ram that need the 64 bit. But if theyve put a lot of new bits in 7022 then i'll put that on instead. Curently using the 64bit Vista Home Premium but will set up a dual boot.
  6. Faust
    Faust
    Dec 21, 2002
    3,525
    UK
    +759
    Given W7 is based on the same kernel as Vista and MS have already stated that all software that works on Vista will work with W7 can you quantify that statement
