Windows 7 RC
tennant
And this is where UAC would shine.
I agree...but my experience is that the people that are happy to use leaked builds are also the same people that disable UAC at the first opportunity!
OK...sweeping generalisations, I know...
Tennant
EarthRod
I wish UAC would shine - all those little boxes! :eek:
Quite like Windows 7 RC build 7100, but after a week or two of fiddling round with UAC I switched it off. Ahhhhh....the relief!
Don't have anything to do with 'leaked' OS - can't see the point.
dave_bass5
The point is the leaked versions are newer and have bug fixes in them.
A lot of people say the latter "leaked" versions run better than the RC. Certainly in my case 7260 runs smoother, with less crashes than 7100.
Each to his own.
Singh400
UAC was given a major overhaul in 7RC. And as a result, it's much less intrusive. I would highly recommend that you leave it on - but at the lowest setting.
Similar threads
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
