Windows 7 on an old laptop
daftpunk1
Im trying to install windows 7 on a toshiba tecra laptop. It only has a 1.6ghz celeron processor and 512mb of ram. It had windows vista when I booted it up so presumed windows 7 would install.
After checking the microsoft website it states 1gb of ram minimum. Is there any way round this. Ive tried windows 7 ultimate and home premium.
Should I try windows 7 starter, what difference is this netbook version to the ultimate version....anything the average user would miss....?
daftpunk1
Windows cannot install required files. The file may be corrupt or missing. Make sure all files are required for installation are available, and restart the installation. Error code: 0x80070017
Ive just installed windows xp successfully and tried again installing windows 7 and no luck.
Disk works fine as I installed it on another laptop 2 days ago....
BrutalUK
I would stick with XP with those specs. Vista will make it suffer even more as it's resource hungry.
daftpunk1
Vista home premium installed fine. Do you think putting another upgrading the ram to 1gb would let windows 7 install...
internetuser
Vista will run like a pig. Xp or windows 7 all the way.
Only time I have seen install errors like that are due to corrupt media or hdd what I am installing onto as windows 7 is more picky about disc checks etc.
I would add up to 3 more gig as memory is dirt cheap
noiseboy72
I run Windows 7 on a similarly basic PC without issue. In fact, it runs better than XP! Its has 768Mb of ram and a slightly quicker processor @ 2GHz.
Podcast: LCD TVs for Movies, Laser Projectors, RIP Ennio Morricone, AV & Movie news, B+W Matt Damon
