Quantcast
Windows 7 Home Premium won't install for Boot Camp
pault2007
I downloaded the 32-bit upgrade version of Windows 7 Home Premium from the Microsoft Store this evening to install on my iMac currently running OS X Leopard (10.5.8) and Windows XP.
I managed to burn the image to a DVD OK but when Windows 7 gets past the Welcome screen, it keeps on coming up with 'A required CD/DVD drive device driver is missing' and won't find anything for me and then I have to exit the setup.
I'm really confused because if the drive can read the DVD then surely the device driver is installed?
I've tried downloading the 32-bit version again (in-case there was a download problem) and installing it but the same thing happens.
I have no reason to believe the download left out some files.
Does anyone know how I can get around this, because, at the moment, I've wasted £85 and wish I'd have just bought it in town?
Thanks.
pault2007
General Zod
Found this from the Leopard Boot Camp instructions.....
If you’re using Windows XP, you cannot upgrade to Windows 7. You can perform a clean install (also called a custom install), which erases your Boot Camp partition. Before you perform a clean install, make sure you have the installation discs for all your programs and a backup of your personal files and settings. You can restore them after the installation.
