Nuck_the_king
Established Member
I have recently upgraded my computer, after much help on this forum.
I have installed XP Pro on the IDE HDD that I have connected to the motherboard. All is working fine.
I also have an internal SATA HDD, which I have not yet installed in XP, because I don't have a floppy drive and so could not create the "F6 floppy" that the XP install process suggests. Device Manager can "see" the SATA drive and reports the serial number with no problems; but I know that I can't use it for anything until I install the drivers (which I have now failed to do in this XP install; so I guess that means I've missed my chance). At the moment, the motherboard BIOS is set to AHCI for SATA drives; and I would know how to change these settings if needs be.
I know that I could do a new install of XP through nlite, but I will be installing Windows 7 when it retails next week (via a DVD they're sending me, as opposed to a download), so I'm not sure I want to go through all that.
So my question is this: if, when I come to install Windows 7, I disconnect the IDE drive and make the
SATA the only HDD connected (and the first Boot option from the BIOS menu), will Windows 7 automatically install on this: and will it find the drivers within Windows 7, or will I still need to download them separately (and therefore probably use nlite to make a slipstreamed installation disk)? Does nlite work with Windows 7 anyway?
The SATA HDD is a Seagate ST325031 & I'm using a Gigabyte GA-73PVM-S2H motherboard.
In Admin tools> disk management, it describes Disk 1 (which I assume must be the SATA drive) as "dynamic" and "unusable". I know a few people like that....
I would be very grateful for any help you can give; hopefully what I have posted makes sense.
