Shady
Hi chaps
After a while of using your PC, you tend to accumulate a load of junk which populates the start up sequence. I am sure in the past I had a set of instructions which allowed the user to clean up the programs no longer required in the taskbar.
Has anyone got these instructions ? I don't always want to delete these programs, just remove them from the taskbar so I can select them from the Start menu when required.
Many thanks for your help.
