Windows 10 UMC22 audio setup help
Discussion in 'Computer Software & Operating Systems' started by Ciaran45, Jul 14, 2018.
  1. Ciaran45
    Ciaran45
    Feb 28, 2018
    5
    4
    Liverpool
    I have purchased a Behringer UMC22 USB audio interface, a Behringer XM8500 Dynamic microphone, connected them via XLR, and connected the UMC22 to my computer via USB 2. In my playback devices on Windows 10 the device is recognised as "speakers", and I can not seem to find a way to record audio with it, even though it is set as the Default Audio Device. Any advice?
  2. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,935
    Norfolk
    +2,548
    Does anything show up in recording devices, particularly if you right click and enable showing disconnected and disabled devices?
  3. Ciaran45
    Ciaran45
    Feb 28, 2018
    5
    4
    Liverpool
    4 options in recording devices:
    My headset microphone
    Realtek microphone - not plugged in
    Line in - not plugged in
    stereo mix - disabled
  4. Abacus
    Abacus
    Jan 19, 2015
    747
    67
    Torbay
    +482
    Seems there is no native driver and you have to use ASIO4ALL instead.
    This interface test may help as it goes through setting up.
    Bill
    Behringer U-Phoria UMC22 Unboxing, Review, and...
