Monster900
As people here may (or may not) recall, earlier in the year, I re-purposed a low energy consumption PC to be a combined PC, for use in the garage and a NAS for data storage/media server. The NAS side of things has 2x4TB WD Reds running in RAID 1 configuration with backup to a separate machine on the network.
Well, with the cold weather I have decided to bring the PC/NAS into the main house as the hard drives were often running too cold. Now here is the problem, if indeed it is a problem, having moved the PC/NAS the two drives have taken the best part of a week to resync. They got there in the end, but it is a bit disconcerting that it takes so long and I'm not sure what the status would be if there was a drive failure while the drives were resyncing.
Now to the questions, as I said I'm using Windows 10 RAID 1 with the drives configured as dynamic disks, would it actually be better to be using Windows 'Storage Spaces' instead? Or, perhaps, it would be better again to buy one of these (available for ~£65 from most suppliers) and configure a relatively inexpensive hardware RAID 1?
As always, thanks in advance.
M
M
