bandyka
G'day,
I wonder if anyone has come across this one.
I am trying to calibrate my OLED B9 and projector for that matter to HDR BT2020 color gamut.
I noticed that I can't see much of a difference between SDR and HDR either when watching movies or playing games. Sure enough after measuring it was the case. There isn't any difference in color between SDR Rec709 and HDR BT2020.
The PC is always in the correct mode SDR or HDR depending on the content I am using so is the display.
I ran dxdiag which reports BT2020 and the TV also reports BT2020 being received however my eyes and actual measurements see Rec709 output only in HDR WCG mode.
The Nvidia settings in use are 60hz 12bit 4:4:4, I've always used these in the past no issues.
The only change I can think of is the new GPU the RTX 2060 Super. The old one was a 1080ti. I think the OS is busted.
I also ran Spears and munsil banding test and the 8bit and 10bit parts look identical which sort of confirms my suspicion.
It suspect the TV only actually receives 8 bit color but I do not know how to confirm that on the TV.
See the image, this is HDR WCG mode which displays Rec709 gamut only.
What am I missing?
What am I missing?
