Window Blackouts - Black Sticky Back Vinyl??
Discussion in 'Home Cinema Building DIY' started by Mark Ward, Feb 19, 2003.
  1. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    I've got some odd shaped arch windows that it's next to impossible to curtain effectively.
    I though I'd try using black sticky backed vinyl over the individual panes. I'd need quite a bit and would ideally like it to come away clean at a later date.
    Any ideas where and what to buy? These are BIG windows.
    Cheers,
    Mark.
  2. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    What about using self adhesive velcro to hold some backout cloth in place? You'd probably have to sew the velcro to the blackout cloth, but it should work OK.
  3. njiri
    njiri
    Oct 26, 2002
    149
    19
    UK
    You could try thick black plastic sheeting. I think it's used as damp-proof membranes in the building trade. I Got some from Homebase, though that was a couple of years ago. It isn't sticky backed, but is absolutely light-proof.
  4. pcdoc
    pcdoc
    Feb 11, 2003
    140
    +3
    I have done that myself Richard, self adhesive velcro on the UPVc window frame (white so it dosen't show up too much) and the Blaclout material I bought had a rubberised side, sticky velcro stuck to it just fine. I have a bay window in whats becomes my Cinema room, I bought 3 metres of the material and 1/2 mtr of velcro, works really well, I get the sun on that window all day when its up shining.
    Cost was £12.97
    Pcdoc
  5. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    Thanks foir the tips.
    I'll try the velcro/blackout solution for the side windows. The odd shaped panes in my large window will nee individual treatment though so I'll try some of the black plastic and gaffa tape on that. I'm a little concerned about the wooden window froms though.
    Cheers,
    Mark.
  6. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,177
    UK.
    +2,714
    I used self adhesive velcro on my loft escape widow to fix hardboard to it. I also used staples to ensure the velcro stayed put on the hardboard. The window velcro seems fine as it is.
    I initialy used black vinyl, but the window is south facing, and the summer suns' heat caused the adhesive to melt and come away.
    The hardboard does a good job, and opens with the window. I can remove it easily if I have to, and it was relatively easy to cut. You can make templates out of cardboard or paper to make it easier to get the shape right with the hardboard.
    HTH
    Gary.
