HouseofMu
Established Member
I know its possible to control WinAmp 2.x using normal remotes but I wish to have more visual control over playlists/tracks.
From hunting around, I've found that a cheap (old) PalmPilot running palmAMP along with its WinAmp plugin, will allow me to do this; but its only a wired (serial port) solution.
I'd hoped I might be able to take advantage of the Palm's IR port, then use an IR extender (eg PowerMids) to transmit to the PC. The PC would have a IR receiver on its serial port, but i've been unable to find an IR Palm winamp controlling program.
Can anybody help with Wireless (IR) Palm solution to control Winamp ?
Thanks.
n.
Thanks.
n.
