Quantcast
Win XP service pack 2 conflict
couchpotato
Hi, I am currently running Win xp with service pack 1a. This works fine with my CCTV software, but I don't get USB 2.0 working only 1.1. If I upgrade to service pack 2 as soon as my CCTV software loads my PC restarts. Is there anyway I can get USB 2.0 to work (Service pack 1 is no longer available, only 1a which for some reason does not enable USB 2.0)
Dragy2k
hi
cant you put any important data on a seperate hard drive and format your main hdd that you use for your CCTV, once formatted and reinstalled xp again add the second service pack or if its out try the third sp (im currently using this myself).
install all your software as normal..i.e motherboard/gfx /sound drivers etc etc and then install the CCTV with a clean install it should run smoothly.
a clean install usually sorts 99% of software probs if your not confident ask a local pc repair shop for a quote
good luck.
couchpotato
Thanks dragy, have tried 2 fresh installs, one with media centre and xp adding the service packs one at a time but still no joy
