Win DVD 7 Media Center Audio Fix
Discussion in 'Microsoft Windows' started by meansizzler, Oct 20, 2005.
  1. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    Ok, by request of a member on the forum, here is a Reg edit so media center will keep the audio settings in media center if you use WIn DVD7 as oyur decoder, this Reg edit will give you 5.1 analogue audio, don't have one for spdif out yet..
    [​IMG]
    Follow the steps in the pictures..., once done 5.1 audio will be set in media center for Mpeg 2 playback, you do not need to go into media center's dvd auido panel and check it will only screw it up again, the Reg edit will set the audio for your in media center, so you do not need to set the audio in Media Center yourself..., to check if 5.1 audio is actual working, play a DVD in media center that has 5.1 audio and while do that go to the DVD audio control panel and 5.1 audio will be listed, do not save anything or make changes there...
