Win 8 - would I benefit ?
Discussion in 'Computer Software & Operating Systems' started by advid, Mar 3, 2013.
  1. advid
    advid
    Dec 25, 2006
    776
    London
    +17
    .I use two laptops and a desktop PC (running Win7) all mainly for work and the 'more serious' side of computing ie. Word/Excel/Powerpoint/Photoshop ect. plus Googling when I need any info. Also a few forums that I use regularly (DS for instance)...
    I really only need an OS for opening a program as above and 'getting on with it'.... I do also have a Facebook and Twitter account but only use once a week - if that....
    Would an 'upgrade' to Win8 be of any benefit to me....if so - what does it do that I can't do or use now...?
  2. DavidT
    DavidT
    Oct 30, 2001
    2,488
    +257
    If you already have Windows7 then there is no reason to "upgrade" to Windows8.
    David
  3. Reinholder
    Reinholder
    Apr 6, 2010
    747
    Plymouth
    +53
    The problem with asking this question is that it's fairly subjective; to be perfectly fair to windows 8, there are moderate improvements over windows 7, but I don't think they're enough to justify the upgrade at this time - however, if you have a touchscreen, I'm sure it would make much more sense.
  4. Wild Weasel
    Wild Weasel
    Dec 11, 2005
    5,641
    The Medieval Warm Period
    +720
    No. And don't get a touchscreen, they are ****.
  5. cougs
    cougs
    Jun 2, 2006
    87
    11
    Kettering
    +10
    Why?
  6. cougs
    cougs
    Jun 2, 2006
    87
    11
    Kettering
    +10
    I've always thought that a decent touchscreen would be good, especially for a jukebox!
  7. cougs
    cougs
    Jun 2, 2006
    87
    11
    Kettering
    +10
    Or a Supplementary screen, to the main viewing screen? Select your media on it, play to main TV?
  8. Wild Weasel
    Wild Weasel
    Dec 11, 2005
    5,641
    +720
    Your arm gets tired after only a few minutes use & you won't use it again other than to show off to friends/family once in a blue moon.
    Touchscreens are fine on a tablet, but on a desktop PC they are a pointless gimmick.
  9. 12harry
    12harry
    Oct 10, 2010
    4,763
    103
    London
    +388
    Win8 is all about MS catching-up with touch so they can work with smart phones and desktops, I understand.
    For keyboard users of Win7, I doubt the upgrade is good sense. MS worked well with Win7, it seems better than Vista.
    Has anyone used the new Gesture device? ...this consists of IR sources and maybe three cameras placed near the screen it can read all five fingers and work out what action you want - presumably it works on two hands as well.
    At present there is little software that takes advantage of this input, but it should eliminate dirty marks on the screen (as with Touch). I suspect it's the future, esp for TV control, but it would have to attach to the arm of the sofa, rather than the TV-stand . . . . . any other input suggestions?
  10. Malwi
    Malwi
    Feb 17, 2013
    3
    As with any upgrades there are always subtle benefits that you do not see on the surface, I paid £25 for the upgrade a few months back and it is well worth it, though I donot have a touch screen interface.
  11. excollier
    excollier
    Sep 9, 2011
    170
    Letterkenny (ex-pat from Staffs.)
    +10
    Upgrade to Linux.........
  12. zt1903
    zt1903
    Oct 19, 2008
    9,504
    +4,439
    Have been using Win 8 on my desktop recently and, to be frank, it's a piece of s**t. Yes it boots up nice and quick but my desktop is not a smartphone and I don't want to use it as such.
    Horrible horrible interface for a desktop computer if you want to do other than shopping and Facebook!
    I'd rather go back to Win 3!
  13. 12harry
    12harry
    Oct 10, 2010
    4,763
    103
    London
    +388
    Ho Hum . . . I've read also that Win8 is a SmartPhone update, but reviewers haven't been so strong to say it's not for Desktops....
    I wonder that MS doesn't offer different layouts for the hardware - this would seem a simple solution, or is it possible zt1903 has selected the "wrong one"?
    I'm using Win7 (32) and that appears to be the equal( for stability, etc.), of Win XP which had a very good following . . . I guess every-so-often MS produces a "Quick-fix which doesn't quite get it right . . . . and they were caught unawares with touch-screens . . . although I understand these are being replace by finger/hand-gestures and the new software can learn the difference (ie hand movements) between different users.
    The advantage of this is there are many more gestures available in one-command than possible with "touch" which in screen Aps is either:- "contact" -or- none. . . . and can make the screen dirty.
  14. zt1903
    zt1903
    Oct 19, 2008
    9,504
    +4,439
    The only "wrong one" I've selected is Windows 8 full stop.
    MS have made the opposite mistake they made with earlier OS where they shoehorned a desktop OS onto mobile devices.
  15. Sonic67
    Sonic67
    Sep 14, 2006
    45,636
    11
    167
    Home
    +24,366
    I agree. I wouldn't go back to Win7 now.
  16. maryancell001
    maryancell001
    Dec 20, 2012
    19
    3
    Placentia
    Just be careful before upgrading to Windows 8 as one of my friends has updated his system to Windows 8 and now he is facing problem with many of his software, but I think the requirement that you have mentioned here can be fulfilled with Windows 8, but be sure for any other software.
  17. Mr_Flash
    Mr_Flash
    Jul 12, 2002
    2,231
    +297
    Download and Install classic shell. Give u a start button then
