My Company Laptop is running win 7 professional.
I have a docking station, which has the monitors plugged in.
Both monitors are VGA.
One is connected via a VGA to DVI adapter.
When I first installed the second monitor last year everything was ok. Then I think after a windows update, the second monitor isnt recognised. I have checked both monitors, cables and adapter on a different pc and everything is working OK.
I try to detect another monitor, but it only finds the monitor connected directly via VGA
I cannot roll back the upgrade cos my company wont allow it. Also, my Company IT support is not very good. Anyway I am in the field, so I cant just ask them to pop over for a look.
Can anyone suggest what has gone wrong and how I can fix this ?
All hardware is OK, I have confirmed this.
