I'm sure you know this, but it's not region free, so you need a NTSC xbox to play it.
Thanks for your link MoogleIve ordered the game from VG+ on your recommendation
... How long does it normally take to recieve delivery from VG+?
Does anyone know if the 360 version is region free?
It depends. It can be as little as 3 days or as much as 5 days. With the issues regards the postal service at the moment it's hard to say whether it will take a little longer then usual.
Gosh thats pretty quick none the less ... im used to play-asia who normally take 10-14 days. As for the 360 version it is definately NOT region free im afraid. Hence why im importing the ps3 version instead. Unfortunately i doubt either ps3 or 360 version will be released in the UK either.
