Will XDA 2 chargers, serial leads work with a XDA2S ??
Discussion in 'Mobile Phones Forum' started by Taz69, Mar 14, 2005.
  1. Taz69
    Taz69
    Apr 15, 2002
    3,483
    Bristol
    +357
    Hi all
    As title, Will the XDA2 accessories work with a XDA2S, why I am asking is I have chance of a GPS which is wired for a XDA2, will it work with the XDA2S
    Taz69 :thumbsup:
  2. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,294
    +7,412
    Have a look here under "what else can I buy". There are different part numbers for the accessories for XDII & XDAIIs so I would say not.
    You could try e-mailing XDA support but my experience suggests that 3 e-mails would produce 3 different answers. :confused:
  3. Taz69
    Taz69
    Apr 15, 2002
    3,483
    Bristol
    +357
    I did see that but the trouble is when you look at the handsets, the connection pins are the same for the XDA2, the S and the I all 22pin USB/Serial, I was hoping to find someone that has had a XDA2 then upgraded to the S etc and used the same kit, becuase like you say emailing O2 is a laugh and they may be putting diff part numbers on to bump up sales for accessories,
    Taz
  4. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,294
    +7,412
  5. Taz69
    Taz69
    Apr 15, 2002
    3,483
    Bristol
    +357
    Thanks Croc, will have a look there
    Cheers m8
    Taz
  6. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,294
    +7,412
    If it helps, I've just acquired a Y lead that supplies power to both PDA & wired GPS mouse. It's labelled XDA & works on the XDSIIs. May even be up for sale in a couple of days if you're interested.
  7. Taz69
    Taz69
    Apr 15, 2002
    3,483
    Bristol
    +357
    Hi all, I have now sourced a nice unit with GPS, its the Holux cradle with built-in GPS, speaker, and charger for the PDA and power for the GPS, very tidy unit, £95 inc spec del from a shop on Ebay.
    It also seems that the XDA2 and the 2s connections are the same, my cradle is marked for the xda2, works fine with the 2s.
    Cheers for your help
    Taz
