will UK games work on an xbox bought in new zealand?
Discussion in 'Xbox Forums' started by cirdan, Jan 3, 2007.
  1. cirdan
    cirdan
    Sep 29, 2004
    230
    +3
    some friends who live in new zealand have just bought an xbox and found the games to be a little more expensive than they thought. i mentioned that pre owned ones here were a few £. so when i next post them they asked if i could get a few games.
    but im not sure if they would work. i think australia would be compatible but ive no idea about new zealand.
    cheers.
  2. daveaka
    daveaka
    Jun 16, 2006
    1,980
    Willington, County Durham
    +266
    Hi, The Format for UK, Europe, Australia & New Zealand are all PAL, so uk games should work fine on an xbox in New Zealand.
  3. triplea4uk
    triplea4uk
    Jan 12, 2002
    2,018
    48
    Northants
    +85
    You could say to them to softmod the xb so then they can run everything.
  4. cirdan
    cirdan
    Sep 29, 2004
    230
    +3
    thanks for the replies.
    i will pass on the info about soft modding, might be something they can do.
    but ill pick up some pre owned games to send to them.
    cheers.
