Will this work?
Discussion in 'Cables & Switches' started by Scoobycity, Jan 12, 2005.
  1. Scoobycity
    Scoobycity
    Dec 13, 2004
    34
    I have a Mitubishi projector which only accepts its component input through the 15 pin VGA input which doubles also as the PC input.
    I wish to use the projector for DVD and PC use and don't want to go messing around with plugs every time so what I was planning to do is buy a component to VGA lead to go from the DVD to the PJ like this..
    [​IMG]
    And a splitter like this...
    [​IMG]
    So I can keep both my DVD player and PC connected all the time.
    The question is do you think I would lose more picure quality by using this splitter than I would gain from using the component connection? Should I just stick to the S-video for the DVD.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    It's a matter or trying I guess.
