will this work
Discussion in 'Cables & Switches' started by strech, Jan 10, 2005.
  1. strech
    strech
    sky from downstairs decoder (2nd tv output) and normal tv from areial into back of tv via a Y splitter in bedroom tv will this work and you get channels 1 - 5 and sky or will the different signal sources make it not work ?
    any help guys
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    ok that post makes very little sense to me... do you want to run sky and analogue TV to a bedroom TV?
  3. strech
    strech
    yes but I have taken the loopthrough out of the sky decoder because that was the only way I could get a very good sky picture via the 4 way loft splitter to the bedroom tv but have lost bbc,itv,4 and 5
    Strech
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    try changing SKY RF output channel then reconnect aerial feed, find a nice clean RF channel one miles from what your aerial picks up and it should give a clean Sky pick as well as analogue TV
  5. strech
    strech
    tried this on every channel one weekend but found the only way was to take the loopthrough out to get the best picture
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    so connect aerial to Sky STB and feeding distribution block with RF2 output of Sky STB meant 1-5 was OK but sky was fuzzy?
  7. strech
    strech
    yes new cable used no brakes apart from loft box all 3 upstairs tv`s were all the same until taking out the loopthrough then perfect
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    can try a combiner may be dodgy RF on sky box
