Will this work? Panny PH7...
Discussion in 'Plasma TVs Forum' started by Claus, Feb 15, 2005.
  1. Claus
    Claus
    I'm trying out the 42PH7 but I haven't got any component or DVI cards yet.
    Can I connect my Denon 3900 via DVI to my iScan HD+ and then from VGA to the VGA input that is standard on the screen?
    Will it serve as a good enough picture?
    C
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    I think you can but will have to use an non copyprotected disk, component from DVD to Iscna HD+ to VGA on plasma will be more reliable.
  3. Claus
    Claus
    Hi Dragon,
    Why?
    I thought the whole point with the HD+ was that it is HDCP encrypted?
    C
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    BUT the VGA on panel isnt! hence the HD+ cant ouput an HDCP signal on analogue (this breaches HDCP protocol)
  5. Claus
    Claus
    But isnt the VGA input analogue. How can it detect it?
    C
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    VGA is analogue mate its RGBHV!
  7. Claus
    Claus
    So how can it detect that the signal is HDCP encrypted?
    Digital from DVD to HD+, then analogue out to screen...
    C
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    because its got a little tag thats says "I'm encrypted" thats why HDCP stops you recording digital HiDef to analogue
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    there are DVD with no encrytpion (macrovision in this case, its the macrovision that kicks in the HDCP and shuts off the analogue outputs) if you have a DVD with no marco vision it will (should work) DVE i think may work, has no marcovision
  10. Claus
    Claus
    But isn't it analogue? The HD+ outputs an analogue signal
    C
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    what isnt analogue......???
  12. Claus
    Claus
    If the HD+ outputs an analogue signal, how can the screen detect the HDCP? It's analogue to analogue.
    I understand it if it's going from digital to analogue.
    C
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    but why DVi if analogue? (does denon do DVi-A???) i dont why DVi out of denon if using analogue why not component?
    Get aDVi board for the panny and no problem
  14. Claus
    Claus
    isn't it better to go digital as far as possible?
    Isn't it better to feed the HD+ with a DVI signal than a component?
    C
  15. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    yes sometimes except it wont work due to copy protection as outlined above........bang 480i or 576i out of denon and let the HD+ to the fancy stuff otherwise you are trying to do too much
  16. Claus
    Claus
    I was thinking this:
    Denon - DVI (576p) - HD+ - VGA (720p) - Screen
    C
  17. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    nah 567i>HD+VGA at 720p or native...............
    let HD+ deinterlace Component>HD+>VGA
  18. Claus
    Claus
    I'll try that.
    Thanks!
    C
