will this work?? Haswell build
Discussion in 'Home Entertainment Computers' started by akki007, Aug 29, 2013.
  1. akki007
    akki007
    Mar 23, 2005
    1,693
    +154
    Ahi folks, I'm out to replace my intel atom nettop that I've been using as a kind of HTPC!
    So, I'm looking at the components below, are they all compatible is my first question, my second is, will I need a dedicated CPU fan and finally, will it be quiet!!
    (I already have a 64gb ssd)
    GIGABYTE H87N WIFI Intel H87 (Socket 1150) Mini-ITX Motherboard - Aria Technology
    Arianet Q5 Mini-ITX Black Aluminium Chassis 120w PSU - Aria Technology
    8GB (2x4GB) Crucial Ballistix Sport 1600MHz CL9 DDR3 Dual Channel Kit [BLS2CP4G3D1609DS1S00CEU] - Aria Technology
    http://www.aria.co.uk/SuperSpecials...t+LGA1150+Processor+-+Retail+?productId=55831
  2. akki007
    akki007
    Mar 23, 2005
    1,693
    +154
    Edited last link as it should have been the processor not ram again!
  3. jammyb2004
    jammyb2004
    Apr 12, 2004
    1,113
    63
    +113
    Intel NUC. Get Haswell next month.
  4. akki007
    akki007
    Mar 23, 2005
    1,693
    +154
    They're mSATA aren't they? I didn't want to buy another drive if poss.
  5. richardb70
    richardb70
    Mar 2, 2005
    5,197
    Reading
    +2,381
    What will you be using the gear for? If it's just HTPC duties then this is vastly overpowered!
  6. jammyb2004
    jammyb2004
    Apr 12, 2004
    1,113
    63
    +113
    Yup. Buy a 30GB mSATA off eBay for £30-40. Can be built off Celeron model for £200 including everything.
    Here's mine - http://forum.xbmc.org/showthread.php?tid=166886
  7. akki007
    akki007
    Mar 23, 2005
    1,693
    +154
    It's overpowered but it will last me longer won't it? Also I might fancy a game of FIFA on it so I can ditch the Xbox!!
  8. deksawyer
    deksawyer
    May 26, 2005
    1,641
    Fife, Scotland
    +132
    For a bit of future proofing, it looks ok, but cpu is OTT just for media playback. If you're gaming as well, then fair enough.
    I'd swap the case for something like an Antec ISK 300-150, which includes a 150w psu. I'd also change the cooler if it's noisy to a Noctua NH-L9i or a Scythe Kozuti.
    I'm waiting to see what the i3 Haswells are like...
    D.
  9. jammyb2004
    jammyb2004
    Apr 12, 2004
    1,113
    63
    +113
    The haswell NUCs have full size SATA port and SATA power. Just need a custom enclosure for it. A lot of enclosures are fanless too!
  10. akki007
    akki007
    Mar 23, 2005
    1,693
    +154
    Well, I built the haswell HTPC.... Amazing!! I've taken photos during the build and a vid so will post a build and result thread tomorrow!....
    Core i5 4430, 8gb ram, 64gb ssd
    It's good. And it plays fifa 13 maxed out buttery smooth!
