Will this work for 7.1
Discussion in 'Home Cinema Speakers' started by terrymul37, Nov 20, 2004.
  1. terrymul37
    terrymul37
    My room is 11' x 11' and the sitting position is against the back wall, is it still possible to use a 7.1 set-up os in this size of room should I stick to 5.1. I am considering the following if I go 7.1.
    Mission Mc2 center
    Mission M30 fronts.
    Mission M3ds for sides and rear.
    Any advice please.
  2. Dfour
    Dfour
    Jan 19, 2004
    4,088
    71
    Bracknell
    +86
    As you have bi poles for the side and rear you should try the 7 speaker setup. I have my seating position against the wall as well and the 7 speakers work well although my room is a little bigger than yours. Im considering replacing the rear bipoles with direct firing speakers to see if that makes any difference as some others have recommended.
