Will this system work?
Discussion in 'Desktop & Laptop Computers Forum' started by tutu, Jun 15, 2004.
  1. tutu
    tutu
    Apr 28, 2004
    2,223
    48
    +58
    Okay I have just ordered the new JVC HV32D40 32" which apparently accepts a 1080i signal through component input.
    The manual mentions 625p, 525p, 625i, 525i, 1125i support through component (not that I know what all that means) ;)
    As I am currently using a Geforce4 Ti4400 presumably I will need to purchase a new ATI graphics card (e.g. 9800pro) and the ATI HDTV dvi->component adapter.
    Do you think this system will work? The ATI mentions for "North america" only. There are also three versions.. confusing.
    Does it have to be an ATI card? What about nv?
    Where can I get the adapter from in the UK?
    Thanks.
