Will this lens be worth waiting for?
Discussion in 'Photography Forums' started by paulg1979, Apr 25, 2007.
  1. paulg1979
    paulg1979
    Sep 3, 2006
    492
    +7
    Hi.
    I currently own a 17-70mm Sigma lens for my 400D but may be interested in selling it for one of these. Would this be wise? It does have Optical Stabiliser.
    http://www.expansys.com/p.aspx?i=141773
    Paul
  2. DaveyD-UK
    DaveyD-UK
    nice range, but not as fast/bright as your sigma
  3. paulg1979
    paulg1979
    Sep 3, 2006
    492
    +7
    Thanks. Maybe i'll pasthen. I really want a lens with a bit more zoom. Whats the Canon 70-300mm with IS any good?
  4. paulg1979
    paulg1979
    Sep 3, 2006
    492
    +7
  5. jonnypb
    jonnypb
    Dec 4, 2005
    4,130
    Cumbria
    +559
    I was looking at that sigma this morning but as it's new theres not really any user reviews of it yet. It will be a bit slow at 200mm
    I've got the 17-70 like yourself and the canon 70-300is is next on my shopping list. it seems a great lens and has £33 cash back at the min so if you get it off kerso it's a little over £300
  6. paulg1979
    paulg1979
    Sep 3, 2006
    492
    +7
    That seems like a good deal. I think thats going to be my next purchase then. I like the idea of IS.
  7. DaveyD-UK
    DaveyD-UK
    The Canon 70-300 IS would complement your Sigma 17-70 really well, the IS will be more useful in the 70-300 range than the 18-200 range.
    I bought the cheaper Sigma 70-300 APO, dont need telephoto often, so couldn't justify a more expensive 70-300 lens
  8. paulg1979
    paulg1979
    Sep 3, 2006
    492
    +7
    The Sigma 70-300mm APO is an excellent lens for the money though. Read some great reviews on that lens. I'd like one but seem to get shakey hand quite often, even on the normal lens.
  9. DaveyD-UK
    DaveyD-UK
    yeah its a great lens for £130, in goodlight it takes reasonably sharp images even at 300mm handheld, on overcast days it really needs a tripod when used above 150mm.
