Will this hurt anything?
Din0Su4r
Would it hurt to have an active sub plugged into an amp? It's only a weak amp, about 60 watts, with two speakers plugged into it. I don't know how powerful the speakers are, but not very. Probably about 25 watts each?
I don't have any other way of setting things up.
Badger0-0
As long as it's low level it'll be ok.
You're a bit vague when you say amp, but as long as it has "sub out", "LFE" or "tape out", it should be fine.
BlueWizard
The questions that need to be asked are -
1.) Does your amp have either Pre-amp outputs or a Subwoofer output on it?
2.) Does you Subwoofer have both Low Level Inputs (RCA-style connectors) and/or High Level Inputs (usually standard speaker connectors)?
It would also help if you told us the specific brand and model of both the amp and the subwoofer.
Steve/bluewizard
