Will this do what I want it to?
Discussion in 'Blu-ray & DVD Players & Recorders' started by storming, Nov 20, 2004.
  1. storming
    storming
    Nov 20, 2004
    17
    I have decided the time has come to purchase a budget model DVD Recorder and my local Makro store has a Goodmans GDVD300R for only £120 + VAT which is the cheapest price I have seen for any recorder anywhere. However as my technical knowledge is somewhat limited I am hoping that someone might be able to confirm or otherwise that this machine will be able to do the following:-
    1. Copy VHS tapes using my old Akai VCR.
    2. Copy programmes/films stored in my Sky+ Planner.
    3. Copy DVDs from my other DVD player ( which i intend to keep using because it is set up with a 5.1 surroud sound thingy).
    4. Copy from a digital camcorder ( which i havn't got yet but should be buying next spring when they have come down in price a bit more).
    If anyone can advise it will be much appreciated. Thanks.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,240
    Warwick
    +2,282
    Out of the four things you list I can guarantee the Goodmans will be awful at all four.
    The Goodmans is based on a Philips reference design and, accordingly, has no Time Base Corrector. Hence it is badly equipped to record from noisy analogue sources - especially if your VCR is below par.
    The Goodmans has no RGB input which means your going to be archiving in S-Video or, even worse, composite :eek:
    You'll need special cables for this (to defeat copy protection) whatever DVD recorder you get. Assuming you get/have got them though again the lack of RGB input means you'll be recording a below average picture.
    And the Goodmans has no iLink connection which makes it less than perfect for doing the above as well.
    Not being funny but there is a reason why the Goodmans is so cheap - it's because it's c***. If you really on a tight budget you would be better off looking at the LG4912 but, if you can push the budget a little bit more, you get much better results from the Pioneer 220 or Panasonic E55.
  3. storming
    storming
    Nov 20, 2004
    17
    Many thanks for the advice. I suppose the old adage " you get what you pay for" will usually be true. It looks like the panasonic E55 could be my best choice and available for under £200 which is the absolute max I want to pay.
    Will it be easy to set it up with my existing Sky+ box and vcr and will there be any expensive "extras" I will need, such as cables etc? Cheers.
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,240
    Warwick
    +2,282
    Do note the Panasonic E55 doesn't have iLink (for a Digital Camcorder). You can still connect via S-Video but it won't be quite as good. For your other requirements though the E55 will be fine.
    Very easy to connect - hook up using Scart cables - how much you invest in these is upto you.
  5. Bosco
    Bosco
    The E55 was/is available from Dixons website for £179.00, it is a web offer only so don't bother going into the store to try get it (it's £239 or something like that in store).
    Also, see my posting on cheepest E85, it's a German website but can be read in english and very cheep too (as are all German electrical websites), it is possible that you could get the E65 for about the £200 mark and this does have the iLink facility that you are looking for.
