hi guys once again im thinking of upgrading was ganna get the A Q 1020IS now im thinking of getting the infinaty betta 10 bookshelf speakers in a 7.1 set up
will this amp run the infinaty betta 10 speakers
itz the marantz sr5003
the specs for the speakers are
Frequency Range 55Hz - 40kHz (-6dB)
Recommended Power Amplifier Range 10 - 125 Watts
Sensitivity (2.83V @ 1m) 88dB
Nominal Impedance 8 Ohms
Crossover Frequency 2.8kHz;24dB/octave
Low-Frequency Driver 130mm (5") CMMD™, magnetically shielded
Mid Frequency Driver NA
High-Frequency Driver 25mm (1") CMMD,
Dimensions
(H x W x D) 300 x 190 x 290mm (11-13/16" x 7-1/2"x11-7/16")
Weight 6.4kg (14 lb)
also are they ok to be mounted on the wall ?
the marantz sr5003 amp specs are
Features
Fully discrete wide range amplifiers delivering 7 x 90 watts RMS
New solid reference standard chassis with hidden front inputs
Dolby Digital Plus, Dolby TrueHD, DTS HD Master Audio and 7.1 Multichannel PCM for High Definition (HD) Audio from Blu-ray Disc™
32-bit DSP with DD-EX, DTS-ES, DTS96/24, CSII and DPL IIx
M-DAX audio enhancer for all compressed audio formats as MP-3, WMA, AAC, etc.
Three HDMI1.3a inputs for digital audio and video including Deep Color support plus one output
Built-in video scaler from I-Chips for up-scaling all analogue signals to HDMI 1080p
HT-EQ (Cinema equalization) and Dolby Headphone
Room Acoustic Calibration with EQ by Audyssey for one touch speaker set-up
Sound delay function to sync audio and video
Clear OSD menu structure and ease of use due to front panel cursor control
Pure direct mode for best audio performance
24-bit/192kHz D/A converters on all channels
Multi-room/multi-source audio by pre-out signal and multi-room speaker in 5.1 set-up
RS232c, IR Flasher port and DC trigger for system integration
will i need a more powerful amp?
thanx loco bro
Dimensions
Features
thanx loco bro
