Will these speakers be ok for the denon 3802
Discussion in 'AV Receivers & Amplifiers' started by 2shy, Jan 31, 2002.
Tags:
  1. 2shy
    2shy
    I have recently purchased a denon 3802 and have the following speakers:
    Kef Q35's up front
    Kef Reference Model 100 centre
    Kef Q15's rear
    Eltax Bipolar's rear
    Will these do? I know they are old, but they wern't cheap when I got them, and would hate to have to upgrade; speakers are so expensive!
    Also, sould the Q15s be surround rear or should the bipoles?
    Many thanks!:p
  2. Jase
    Jase
    Mar 16, 2001
    10,722
    United Kingdom
    +2,491
    The Kef´s are excellent speakers, youve got no problem at all.
    They´re also a good match for Denon equipment.
    I´d have the Q15´s as the Rear Left & Right (as they match the fronts) and the others as rear centres, it might be worth you investing in another pair of Q15´s to replace the Eltax´s so you have a perfect match all round. You could still keep the Eltax´s as the Surround B speakers, the Denon has connections for 2 sets of surround speakers as well as the rear centres.
    Also invest in a subwoofer if you dont have one already!!
    cheers
