Hi Everyone,
I am new to the forum and really after some good advice with regards to my home cinema set up.
The kit i have at the moment which isnt installed is -
Optoma HD 200x Projector (1080p)
Sky HD
Sony PS3
Onkyo TX-SR605 7.1 HDMI Receiver
KEF Q35.2 Floorstanders
KEF Cresta 1 Bookshelf Speakers
KEF Coda 80 Centre
Mordaunt Short MSW20 Subwoofer
Now,
The plan was originally, to have the Cresta and Coda built into the wall where the fixed projector screen would be. These would sit on boxes as such so still some room around, but on rubber pads to stop vibration
The Floorstanders were going to be my rears.
Then i changed my mind, and decided to have the Q35.2's as the fronts, just sitting on the floor, the Coda 80 as the centre and use the Cresta as Rears on Brackets in ceiling corners.
I have just been reading a bit about Warm/Bright combinations and i may have gone wrong.
Is Onkyo/Kef going to sound okay?
I really want to hear some good bass, thats why i bought the Mordaunt sub but i want to ensure the speakers i have are good enough.
I may sell the ones i have and buy better ones if they are going to be needed?
Any advice would be great guys.
What bookshelves should i use?
Will the floorstanders sound okay as they werent the most expensive set but appear to get good reviews?
Thanks in advance
Barry
Sky HD
Sony PS3
KEF Coda 80 Centre
Now,
Thanks in advance
Barry
