Will there be DPL II receivers out soon for under £600?
Discussion in 'AV Receivers & Amplifiers' started by samhassall, Jun 21, 2001.
  1. samhassall
    samhassall
    I am looking for an AV receiver for under £600. Does anyone know if imminent products such as the Denon 2802 and Pioneer VSX860 will have DPL II on board?
    Should I wait for these new models, or just go for the current ones?
    My current equipement is:
    Toshiba 28WD98 TV
    Pioneer DV-340 DVD
    JVC HRS-8700 VCR
    I am planning to add a speaker package to this system, which will be either a Boston System 8000 or Monitor Audio Baby AV1 (both for asthetic and partner pressures).
    Hope someone can help. :)
    [ 21-06-2001: Message edited by: toshy ]
  2. loz
    loz
    Jun 4, 2001
    13,062
    +1,787
    The Onkyo TX-DS595 features DLP-II and is already available.
    Retail £449
    And mighty fine it is too.
  3. loz
    loz
    Jun 4, 2001
    13,062
    +1,787
    Oh, and if you want partner-sensitive speakers why not use the Kef 2005s.
    This is the combination I have.
    Superb.
  4. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
  5. samhassall
    samhassall
    Wow, £360 for a DPL II receiver from Onkyo! That's a major bargain. I had to look twice on QED to make sure it was true. Have there been any reviews of it anywhere?
    I may wait to find out if the Denon and Pioneer models will have DPL II, but I bet I won't get either one for £360?
    Then again maybe it will be worth spending an extra £250 or so to get a THX certified model from Pioneer, although I have heard that the VSX859 was good at doing an impression of a barbeque! Hope the 860 doesn't do that.
    Does anyone know when the AVR2802 or VSX860 will come out so I can make a comparison between them and the Onkyo 595?
  6. samhassall
    samhassall
    I looked on www.onkyo.net, and the 595 has a DTS decoder on board which is great. But it doesn't mention that the 595 has a DD decoder on board. My DVD player doesn't have a DD decoder either. Does this mean that I won't be able to listen to DD Discs when using the 595?
  7. loz
    loz
    Jun 4, 2001
    13,062
    +1,787
    I thought it was pretty clear in the Features list but I suppose you might have been a bit confused by the wording, as it says DTS Decoder, but only says Dolby Digital, (i.e. no mention of Decoder), but rest assured it does have DD Decoder.
    I would be surprised to see a mainstream AV Receiver in the UK that didn't!
