will the Yam rxv 2400 fry my rears
Discussion in 'AV Receivers & Amplifiers' started by kid rock, Jan 7, 2004.
  1. kid rock
    kid rock
    Dec 10, 2003
    316
    frankfurt germany and cardiff wales
    +9
    I am very keen on this amp but have run into conflicting advice from 2 dealers.My current rears are the Mission77ds rated at 70watts rms . Dealer no 1 says that the Yam will fry them for sure as it is 7+ 120 watts per channel. Dealer no2 says it will be ok as in reality the Yam only outputs 70 -80 watts all channels driven. I am keen to keep the Missions as they integrate well into our listening room and would like to add another pair for full 7 channel duties. What do people think --advice gratefully received.
    Kid Rock
    :rolleyes:
    System: NEC ht1000, Nec Plasmasync, Arcam AvR200 ,Mission 773e fronts, 77c1 center, 77ds rears, B+W asw 675 sub.Pioneer dv 737
  2. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,091
    notts.
    +64
    Hi Kidrock
    I think if all speakers are set to small (crossover80hz) rest sent to sub you would be ok.I used the m7ds with my nad t752 which output a true 90 watts per channel all channels driven with no problems ,other forum members use them with amps more powerful than this with no adverse effects.
    Cheers Gonzo.
  3. CARLOS
    CARLOS
    Feb 11, 2001
    6,464
    WEST MIDLANDS
    +1,412
    It should be fine unless you plan on running the amp at full output continuously !
    You are normally more likely to damage the speakers with an under powered amp (Amp start clipping and voice coils in the speakers overheat !).
    P.S Good choice of amp ;)
  4. RobDickinson
    RobDickinson
    Mar 8, 2001
    4,756
    Christchurch , New Zealand
    +748
    speakers can take a lot more than there rated for peak power.
    as said unless your running the yam at 100% all day shouldnt be a problem - I doubt you'd be running the yam over 50% anyhow?
    Its far easier to kill speakers with an underrated amp pushed to far and clipping.
  5. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    Who are these dealers? Do they know anything?Dealer 1 is the better sales person a least he is trying to make money out of you for no reason other than to make money.
  6. CARLOS
    CARLOS
    Feb 11, 2001
    6,464
    WEST MIDLANDS
    +1,412
    Lol :)
