Will the Tosh 220 or Sony NS305 play DVD-R discs
Discussion in 'Blu-ray & DVD Players & Recorders' started by Messiah, Mar 1, 2003.
  1. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Title should read Tosh 220.
    Does anyone know if either of the above two players will play DVD-R discs.
    Thanks.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,720
    Warwick
    +2,599
    The Toshiba will certainly read DVD-Rs - I have one and use it as my main DVD player to play disks that I have burnt on my HS2/PC.
  3. dr_mabuse
    dr_mabuse
    May 4, 2002
    566
    28
    utopia planitia
    +26
    Hi Messiah
    go over to www.vcdhelp.com and check their compatability lists - that's where I got info when considering which player to choose for +RW compatability. You can even e-mail people who've left comments in some cases.
    Also try www.doom9.org - check the forum.
    HTH
    dr_m
  4. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Thanks both.
  5. bobbles
    bobbles
    sorry for hijacking but it does seem as though your qu has been answered
    i can also confirm -R plays on 220
    Raz, is this because you use the HS2 to record onto -R while you are watching something else on the 220. Do you think the 220 gives a better quality playback? It does have component
    why isn't this standard on all dvds?
    I ask because I have a similar set up E30 and 220 but have put the 220 upstairs as it seemed daft having two downstairs
  6. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    No probs bobbles. Any idea where I can get an E30?
    Neil
  7. bobbles
    bobbles
    multiregion have it for 450 ish multi natch
    tecknotronics have it for a similar amount but some members have posted bad experiences with them
    I am sure i saw it multiregion from RS for 399.95 in a mag offer (widescreen?)
    The E30 has been replaced with the E50 now, basically the same model though
    If you can afford it get the HS2 though as it has excellent editing facilities
    even with sky+ i am frustrated with the lack of editing I can do with the E30
    -RAM editing is superb but -R discs are so much cheaper
    there was a recent thread with a link to a site selling the HS2 for 500
    seems a bit too cheap to me though
  8. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Thanks bobbles. Think you may be referring to this thread which is only speculation although sure it will happen at some time in the not too distant future.
  9. Rasczak
    Rasczak
    Apr 3, 2002
    21,720
    Warwick
    +2,599
    I use the 220 as a playback machine because the HS2 is normally busy doing dubbing or recording when I want to watch something on DVD. Therefore the 220 remains my DVD player.
  10. bobbles
    bobbles
    which do you think gives better performance?
    I would have thought the E30/HS2
    There doesn't seem too much difference to me
    wrong thread
    This one
    but it was too good to be true
    without a doubt the price will drop to that kind of figure in the near future
  11. Rasczak
    Rasczak
    Apr 3, 2002
    21,720
    Warwick
    +2,599
    I can't really compare them. Although I record the RGB signal from Sky+ on the HS2 my (soon to be replaced TV) only has one RGB scart so I use the S-Vidoe output from the HS2. This obviously can't match the RGB picture from the 220.
    Additionally half my DVD collection is region 1 and I didn't get a modified HS2 so can't give a full side by side test.
