Will the Tag Play DTS 96/24 ???
Discussion in 'TAG McLaren Audio Owners' Forum' started by m0v1em4n, Jun 20, 2005.
  1. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    819
    Derby
    +48
    Hi All,
    does any one know If my Tag AV32r 7.1 ( single processor no 192 dac upgrade) will play the DVD,s that are poping up now with the DTS 96/24 sound tracks,
    Just got the Region 3 version of Phantom of the opera DVD from cdwow and it as a DTS 96/24 track but only shows as 48 on the tag,
    I am playing the DVD via an HTPC using onboard sound card connected by a s/pdif,
    The view over at AV Forum US seem to be that its a new formate and want play if the Tag is not geared up for it, check it out here
    Don't mind getting a better sound card if this would help
    any info would be great
  2. Kinofan
    Kinofan
    AV32 is doing that. :)
    Maybe you have to look at your HTPC if the sound on board is able to do that and/or your settings are correct.
  3. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    Not the SP version, only the AV32DP.
  4. babaroga
    babaroga
    Aug 27, 2003
    208
    Hertfordshire
    +4
    Stevesky, can you ellaborate a bit more on DTS 96/24 please ?
    It there any real benefit of having it ?
  5. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    This DTS leaflet sums it up reasonably:
    http://www.agmdigital.de/3/files/9624FAQ2.pdf
    Worthwhile having? Well from <24kHz the information will be the same as decoding it using a normal DTS decoder. Basically you have a Core audio part that all DTS decoders understand, this gets decoded and upsampled to 96kHz. You then have extension data that supplies the spectral info from 24-48kHz, result is 96kHz audio. It's a step nearer to the original master, but you have to remember that DTS is a lossy format and the format is showing it's age compared to high bit rate WMA, AAC MPEG 4 etc.
  6. babaroga
    babaroga
    Aug 27, 2003
    208
    Hertfordshire
    +4
    Thanks Steve !!!!
  7. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    Hi Steve, sorry to highjack the thread s. morris :) Steve, in theory would the DP platform be able to handle the newer formats such as WMA?
  8. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    In theory yes. Might be tricky to do WMA and ceiling speaker support though.
  9. babaroga
    babaroga
    Aug 27, 2003
    208
    Hertfordshire
    +4
    In theory it can do FLAC as well, but who's to write the firmware ?
