Will the PV500 do everything the 435xde does?
Discussion in 'Plasma TVs Forum' started by PioRow, Mar 21, 2005.
  1. PioRow
    PioRow
    Jan 28, 2005
    848
    +19
    I had decided on buying a 435xde when my bonus and pay check came in (mid april) but now I see the spec for the Panasonic TH-42PV500.
    In peoples opinions from looking at the spec sheet and by panasonics track record will the PV500 be able to do everything that the 435xde does?
    It looks like its the same res and supports HDCP over HDMI. Given panasonics good track record with analogue inputs and the 435xde supposidily less than spectacular performance with analogue inouts do people think its worth waiting for the PV500? When will reviews be avilable, if its released early may will it be likely opinions will be available on the screen around the same time?
