Will the following work?
Discussion in 'Cables & Switches' started by GasAttacK, Dec 19, 2006.
  1. GasAttacK
    GasAttacK
    Will the following work and are they HQ cables?
    1) This cables: http://www.db-cables.co.uk/index.php?main_page=product_info&products_id=184
    To connect the following 2 devices:
    Denon RCD-M35DAB Mini Hi-Fi
    http://www.radio-now.co.uk/Denon_D-M35DAB_hifi_mini_system.htm
    Sony KDL-40w2000 LCD TV
    http://www.sony.co.uk/view/ShowProd...B&pageType=TechnicalSpecs&category=TVP+LCD+TV
    AND
    2) This Cable:
    http://www.db-cables.co.uk/index.php?main_page=product_info&cPath=75_66&products_id=182
    Pioneer DVR-920H DVD Recorder
    http://www.digitalhomemag.com/revie...d=36407&subsectionid=1306&subsubsectionid=957
    I plan on connecting my Sky HD box and PS3 to the Sony KDL-40w2000 LCD I mentioned above using HDMI but am looking for the best way to connect the DVD Recorder and Hi Fi; will the cables I've listed above do a good job or can you suggest anything better (Price not really an issue)?
    Also, how many HDMI connections has a Sky HD box got? I was just wondering what the best way to connect my DVD Recorder mentioned above to the Sky HD box would be. The DVD Recorder has HDMI connections which would not be used for the LCD because the TV's 2 connections are already taken, so could I connect the DVD Recorder to the Sky HD using HDMI.
    I would really appreciate links to high quality HDMI, Component and Coax Phono leads.
    I would be grateful for any help; thanks in advance.
  2. philaitman
    philaitman
    Oct 17, 2006
    920
    43
    +159
    You can get the same hand made cables cheaper from Mark Grant Cables.
    Look in the powerbuy at the top of the forum or visit his web site. Excellent quality and fast delivery.
    And yes they are good quality cables.
