Will SkyHD box still work with Hard Disc removed
Discussion in 'Sky Digital TV Forum' started by zanc, Feb 10, 2009.
  1. zanc
    zanc
    Sep 25, 2002
    158
    St Ives, Cambs
    +8
    No longer subscribe to Sky. I was thinking of selling the box, but instead thought I could scavenge the hard disc from the box and still run it as a receiver, using the disc as a PC backup drive.
  2. Martin J.
    Martin J.
    Dec 19, 2006
    1,406
    +175
    Actually, yes it will. Or at least in my experience, the Thomson branded boxes will work without a hard disk. Obviously, you'll lose all the PVR functions.
  3. Bachstrad
    Bachstrad
    Sep 4, 2006
    4,077
    Bristol
    +262
    He's already lost the PVR functions as he's ceased his subscription.
    ATB
    Max
  4. Rob.butters
    Rob.butters
    Jul 19, 2007
    581
    28
    Moved from Wallington to Alaska
    +29
    So basically its a massive STB......
  5. newboy2008
    newboy2008
    Dec 12, 2008
    901
    28
    +90
    we have a second HD box(non multiroom) in our bedroom.Mainly used for BBcHD and channel4Hd.I may well take out the hard drive as it is making really anoying noises.(drive sounds awfull)/.If I cant get rid of the noise I may well remove the drive ,now I have read this.Not even sure why the drive is working at all,since its not used as a PVR?
  6. pcbbc
    pcbbc
    Jul 23, 2003
    397
    28
    London UK
    +84
    On some models - Pace PVR2 for example - the power light stays stuck on green in standby without a hard drive.
    Don't know if the same is true of the HD boxes.
  7. newboy2008
    newboy2008
    Dec 12, 2008
    901
    28
    +90
    tried removing the hard drive from my Thomson hd box(component).It would not come out of standby with the hard drive unplugged.
  8. zanc
    zanc
    Sep 25, 2002
    158
    St Ives, Cambs
    +8
    I also tried removing the drive. It will not come out of standby without a working disc. It needs both power and SATA connectors. Also tried removing the drive after it had started and it continued to work. However, if you put it to sleep it would not wake up from sleep with no disc. So it seems you do have to have a working disc in the box for it to startup.
  9. Cyril
    Cyril
    Jul 20, 2005
    1,113
    48
    +39
    None of my 3 Thomson boxes or my Pace boxes work without a hard disk.
    I have tried a smaller (200GB sata) drive and that allows you to boot up.
    Anyone tried it with a small IDE drive, say 30GB and a SATA to IDE adapter?
  10. icek00l
    icek00l
    Nov 21, 2011
    12
    I have just removed the hard drive in my Thomson HD box and it works fine, goes into standby and restarts, all without that horrid fan clanging away! :)
  11. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    Well, lots of things have changed in 4 yrs!!
