Will Sky HD be able to send non-HD signal to my CRT too?
Discussion in 'Sky Digital TV Forum' started by Oakleyspatz, Mar 27, 2006.
  1. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,704
    Woking
    +237
    Ok, I have an Infocus 7205 HD projector and have pre-booked Sky HD. It has suddenly occured to me that my daytime viewing will be on my CRT which is NOT HD ready or capable. Does anyone know if the new Sky HD box will be able to send a standard signal say via scart, to my CRT as well as a HD signal to my projector?
    If not, I will have to fork out for a new TV as well!
  2. xavster
    xavster
    Apr 14, 2004
    490
    28
    +38
    I'm in the same position....
    Fingers crossed it'll be ok, but otherwise, it should only be a couple of menu presses to set the box to the correct output (might even set this up as a macro on my remote)
  3. blakey1
    blakey1
    Sep 21, 2005
    1,781
    48
    +40
    The HD box has scart connections and you connect it to a CRT no problem
  4. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,704
    Woking
    +237
    Cheers Blakey, that's put my mind at ease!
  5. Mike_CA
    Mike_CA
    Mar 20, 2006
    622
    28
    +54
    Also it has a coax output. If it's like the US boxes, everything is outputed in analog SD on the coax.
