Will my sound improve if i use my DVD's on board decoder?
Discussion in 'AV Receivers & Amplifiers' started by DaBuzz, Feb 1, 2001.
  1. DaBuzz
    DaBuzz
    I have a Yamaha DSPa-595a and a Pioneer 626D DVD Player. I use an IXOS Coaxial Cable to connect it to my DVD Player.
    The sound is fantasic, however I am trying to think of ways of improving it furthur. I was reading the Review of the Pioneer on this site and HC said that they could not tell the difference between the Onboard decoder on the Pioneer and a Yamaha DSP-A1.
    This got me thinking. If I used my Pioneer to decode the signal instead of the Amplifer then would i get any improvment in performance? (this would be done using the 6 channel inputs).
    Well?
    Any help would be grateful!
  2. Confucius
    Confucius
    Feb 1, 2001
    2,148
    Oxford
    +132
    Without wishing to be flippant, there is only 1 way to find out..............
    K'ung Fu-tse
    The poster formerly known as PeteH, who is awaiting an apology from a certain individual....
    Stuff up for auction on E-Bay
  3. RUWANDIGITAL
    RUWANDIGITAL
    What I personly think is NOT.
    Well you used for the digital output of your dvd player to your receiver a digital Coaxial RCA cable.
    This caus a better sound quality than 6 analog cables i think.
    Gr. Ruwan
  4. HT Dude
    HT Dude
    Isn't there generally better decoding in integrated amps/processors?
    I would have said avoid on-board decoders.
