Will my screen bring down my cealing??
Discussion in 'Projectors, Screens & Video Processors' started by dave1de, Mar 26, 2005.
  1. dave1de
    dave1de
    Nov 16, 2004
    2,095
    48
    +33
    I am in a bit of a tricky situation.
    First of all, the screen is going to pull down over a wall and door. It is pritty heavy and when i bang on the cealing it seems very hollow, so im not really wanting to mount it there. However, the door frame goes right up to the cealing and has a glass pannel in between the door and the cealing. I thought of sawing away the sticky out bit of the frame and putting a piece of wood up accros the wall, just under the cealing, would this be able to hold a screen? Also, the fitting seem very small to hold the amount of weight the screen weighs.
    Cheers guys
  2. Tiesto
    Tiesto
    Mar 26, 2005
    99
    11
    HI dave1de, i have a new 2m x 2m R/C Sapphire screen mounted directly to my plasterboard ceiling using proprietory plaster board fixings,(4 in total) they have held it fine for the past two weeks , no problem.
    :D
  3. Beastie Boy
    Beastie Boy
    I would try and fix some wooden battons between the ceiling joists and screw directly into the battons.
    Plasterboard is not meant to be load bearing.
    Cheers, Beastie.
  4. David_of_Surrey
    David_of_Surrey
    Oct 13, 2004
    200
    +6
    Somewhere in the ceiling should be 2 inch wide joists at 16 inch centres these will normally run in one direction across the room. once you find one it should be easier to find the rest, you can buy a "stud finder" from a diy shop that will help find them.
    Once you think have found one test by drilling a very small hole (1/16 inch 1.5mm dia or so) to check, the stud finder will also help locate any cables in the ceiling.
    Dave
  5. dave1de
    dave1de
    Nov 16, 2004
    2,095
    48
    +33
    Hi cheers for all the advice people.
    I have put in 2 wooden brackets just under the cealing so it sticks out over the door frame and it works perfectly.
    As I already have an uploaded picture of the screen you can see how it is done on this thread:
    http://www.avforums.com/forums/showthread.php?t=199987
    Its on my last post.
