Will my panny PW7 plasma support HDTV on the XBOX 360 ?
Discussion in 'Plasma TVs Forum' started by jamieuk23, Jul 22, 2005.
  1. jamieuk23
    jamieuk23
    Oct 25, 2004
    2,173
    +26
    I have done some searching and reading around these forums as the topic of HDTV seems to be very confusing.
    to get straight to the point. I have a PW7 42" plasma will this work well with the XBOX 360 regards to best picture Quality, HDTV resolutions etc ??
    I am just a little confused if sky TV HDTV and console HDTV are the same thing ?
    thanks for your help
  2. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    Microsoft have confirmed the current Advanced AV will work with HD content on the Xbox360 so you'll be able to access it through component,they have also confirmed that a VGA cable will also be released allowing access to HD,both these connections are available on the PW7, VGA is built in,Componet through an add-on board.
    As far as resolutions are concerned, the PW7 will display Xbox360's 720p/1080i HD outputs but the picture will be scaled down to match the resolution of your screen, whether it will look significantly worse than a HD Ready plasma is unknown until the Xbox360 is released.
  3. bluevortex
    bluevortex
    Feb 6, 2005
    1,912
    +76
    is it true that the Pw7 can show true HD by using a scaler?
    If so, what scaler would any of you suggest and what sort of price?
