Will my old tv stand glass take the weight of my new lcd?
Discussion in 'Home Cinema Buying & Building' started by RGP, Oct 29, 2005.
  1. RGP
    RGP
    Oct 26, 2005
    1,488
    St.Albans, Herts
    +32
    Hi :)
    currently got a Sony 28" FQ75 on its original stand, it stands on the three pillars, will say a 32" lcd (weight 21kg) be ok to just stand on the glass shelves between the pillars, where normally a video or dvd would sit, will the glass crack & break?
  2. nick501
    nick501
    May 6, 2005
    7,217
    Walsall, West Midlands
    +782
    why dont you get something else roughly the same weight and try it?
  3. UKBOY
    UKBOY
    Dec 2, 2003
    1,612
    63
    +176
    I would have thought that provided the stand of the LCD covers at least half the width of the footprint of the previous tv you should have any problems.
    If it was a 21kg stilletto placed in the middle then you might have problems but otherwise I would expect the glass to be rated well in excess of the weight they tell the consumer.
    UKBoy.
  4. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    24,739
    2
    In a secret location with Jennifer Lawrence
    +12,243
    It should be fine. I reckon your CRT TV weighs loads more than that. Had my old Sony 28" CRT on a cabinet which was starting to groan under the weight but my new 32" LCD TV is loads lighter.
  5. RGP
    RGP
    Oct 26, 2005
    1,488
    St.Albans, Herts
    +32
    Yeah it weighs more (approx 50kg), but sits on the 3 pillars & not the glass its self, more of a question of what the max weight can the glass handle.
  6. alanwalton
    alanwalton
    I would have thought a decent peice of wood about the sieze required,put under the TV to spread the load.
