Will my magic eye work with Sky+?
Discussion in 'Sky Digital TV Forum' started by andrewmellor, Jul 11, 2003.
  1. andrewmellor
    andrewmellor
    Dec 17, 2002
    1,533
    38
    Nottinghamshire
    +22
    We currently have a remote 'eye' fitted to our existing sky set up and are having Sky+ fitted next week.
    The sales people told the wife that we need a new eye and remote (£90!!) but I was thinking we could use the eye and just get hold of a new remote (£25ish?) and then use the + facilities.
    Can anybody confirm that the old eye will work OK or not?
    Cheers..Andrew
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Any TVlink style device that works on a standard digibox will work with SKY+ once the RF2 power is turned on and the RF channel output is correct.
    There is no reason why you have to buy another one especially for £90, however you should invest in a second SKY+ remote :)
  3. TheBigApple
    TheBigApple
    Dec 10, 2002
    665
    In my cage
    +13
    Yes I have just had Sky+ installed and the eye definately works.
    I got an extra Sky+ remote from Sky for £20
    By the way I was given the same waffle about having to buy a different eye.
  4. andrewmellor
    andrewmellor
    Dec 17, 2002
    1,533
    38
    Nottinghamshire
    +22
    Thanks for the confirmation...as I suspected, the Sky sales team are trying to earn their keep!!
    Monkeyboy...did you just call the sales line for the extra remote?
    cheers..Andrew
  5. TheBigApple
    TheBigApple
    Dec 10, 2002
    665
    In my cage
    +13
    Yes when I thought the sales muppets were fobbing me off I got put through to a supervisor in sales who ordered the remote.
  6. philinman
    philinman
    Jul 6, 2002
    408
    shropshire
    +4
    The standard eye will work but at the moment Sky are having problems with some V2 boxes as the 2nd rf output doesnt work cporredtly
    Sky came to replace my box today as my eye wont work and the new box had the same problem, After them blamimg the cabel ect and the eye they fitted a standard digi box and it worked no probs .
    So make sure you test the function before the engineer leaves mate
    :hiya:
  7. andrewmellor
    andrewmellor
    Dec 17, 2002
    1,533
    38
    Nottinghamshire
    +22
    oooerr..engineers been and gone now.
    I read on here about v1 and 2...I'm assuming we will have had
    v2 fitted this morning.
    Are they all the same make, is it pace??
    cheers...Andrew
  8. philinman
    philinman
    Jul 6, 2002
    408
    shropshire
    +4
    if its just been fitted it will be a v2 thay are all pace but an amstrad one will be avilable soon.
    yours should be silver almost white in colour if its a v2
  9. andrewmellor
    andrewmellor
    Dec 17, 2002
    1,533
    38
    Nottinghamshire
    +22
    Yes, it is V2 the pace silver/white one.
    Not tried the eye yet....wife busy recording/watching soaps:)
    I'll give it a try tonight and post back!
    cheers..Andrew
  10. pwarren
    pwarren
    For what its worth, I've got the old sky+ box with a remote eye running upstairs, the eye is old, purchased when I had a pace digibox.
    The reason for the post is that I rang up to order an additional sky remote for upstairs and mentioned in passing that its a bit off that I had to pay for another remote having purchased 2 standard remote a while ago. She agreed and sent one free, in a wicked white colour.
    Thought you might want to know, or even give it a go. Especially if they ring you trying to flog you sky+.
    Take it easy
    Warren
  11. alpha10
    alpha10
    Jan 22, 2002
    3,197
    Essex
    +191
    Just phoned to order my Sky+ and was told that my magic eye wouldn't work, I queried this the little boy went away and came back and said, yep definitely won't work??
    I suppose they were going to try and sell me another link...
  12. adeyb
    adeyb
    Jul 28, 2003
    243
    Cheshire
    +10
    works sometimes, not others, its pot luck
    I have a V2 Box, have swapped the eye with my mums and its the same, the voltage is always there (the light is on and ive tested with a multimeter) but sometimes the commands just dont get thru.
    Odd, very odd
    :zonked:
  13. James_Stockport
    James_Stockport
    May 23, 2006
    17
    New Mills
    I'm having the same problem, i have just changed the layout of my living room and decided to hide my sky box. I have never had a magic eye until now. i have had the sky+ box for 17 months now (could this be a V2). I connected a new magic eye and nothing.
