Will my existing 75/100 vesa wall mount fit my new Samsung LE26R41BDX??
Discussion in 'Home Cinema Buying & Building' started by martind, Jul 29, 2005.
  1. martind
    martind
    Jul 29, 2005
    1,205
    38
    Birmingham
    +20
    I have finally taken the plunge and ordered the Samsung LE26R41BDX after reading various threads over the last couple of days (play dot com £599 seems like a bargain, just gotta wait for it to arrive now!!!).
    Anyway, I will be replacing an 19" LCD monitor (with very basic tuner) that is currently hanging on the bedroom wall using a vesa 75/100 wall mount, what I intend to do is use my existing wall mount but I can't find anywhere on this forum that can confirm if the Sammy LE26R41BDX will fit the 100x100 bracket.
    200x100 has been mentioned, but I can’t find anyone who has really stated if 100x100 will fit or not.
    Please help, if I do need to order another one, I want to do so before the set arrives.
    Ps. Would you connect a PS2 using Component/Audio, Scart or RCA??
  2. AlpsUk
    AlpsUk
    Apr 3, 2005
    3,504
    Wellingborough
    +909
    The lcd is definitely vesa 200 x 100. As regards to the ps2 component cables will give the best pq.
  3. martind
    martind
    Jul 29, 2005
    1,205
    38
    Birmingham
    +20
    Cheers mate, so i take it that 100x100 will not fit?
    Any recommendations on a 200x100 mount? I will need to fit it to plasterboard screwing into the wooden struts behind the board so a wall mount that attaches to the wall with the screws aligned verically would help.
    Thanks again
  4. AlpsUk
    AlpsUk
    Apr 3, 2005
    3,504
    Wellingborough
    +909
    The holes are too far apart for the 100 x 100 mount.
    Try this for a mount. link
  5. quinnmar
    quinnmar
    Jul 25, 2005
    321
    +39
    You can try https://www.medionshop.co.uk/
    Product number 50020670 facilitates 200 X 100mm
