Will My Dvd Play Rce
Discussion in 'Blu-ray & DVD Players & Recorders' started by bigjonnyauk, Oct 12, 2003.
  1. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    742
    midlands
    +17
    hi all
    just seen the new bad boys 2 will be rce and i have never put a rce in my player
    i have a tosh sd220 that is chipped so it auto does the region
    i hear that rce will only play on manuel switching dvd players
    please dont say it wont work as i have been looking forwrd to this
    cheers
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,310
    +1,217
    My pioneer 444 plays RCE with auto region no problem why not buy a cheap S/H RCE disk and try it out see if it works! If not sell it and all you have lost is postage!
  3. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    742
    midlands
    +17
    i just spoke to my sis and she has a ghost of mars so i think i will try that and hope
  4. spiderv6
    spiderv6
    Dec 12, 2002
    138
    16
    my machine is pre-RCE and auto region. In that mode it will not play RCE disks, all I do is force it to region 1 and then it does not complain. you may be able to do the same.
  5. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    742
    midlands
    +17
    yes i have looked into this but cant find how you force a tosh sd220 into region 1 ???
  6. Pooon
    Pooon
    Dec 26, 2002
    7,315
    Canterbury, Kent
    +918
    I have a tosh 520 that auto selects the region and have had no problem with rce disc's, so i would think your 220 model would be fine. got mine from Richer Sounds if that makes any difference.
  7. dr_mabuse
    dr_mabuse
    May 4, 2002
    566
    28
    utopia planitia
    +26
    bigjonnyauk
    Well I had an older Toshiba admittedly but I had to do the T1 C1 remote keys to circumvent RCE. Once done you can then hit menu to go back and fix the audio. I only have Final Fantasy as RCE but it worked fine on that disc. Just don't try to locate the extras!! (you won't believe how many remote taps it took me to find the sexy images of Aki!!)
    HTH
    dr_m
  8. alfablue
    alfablue
    Aug 16, 2002
    287
    19
    I was told when I bought my modded Pioneer player with auto region selection (from Sevenoaks in Bristol that I could insert another R1 disc, then remove it and insert an RCE region 1 disc and it would work - never tried it (not got any RCE discs) but it might work on yours too!
  9. Demon
    Demon
    Dec 13, 2000
    961
    Cheltenham
    +63
    I have 4 RCE Titles that all play fine in my SD220 without any hacks or anything, So unless they've changed how RCE works, then it should be fine.
  10. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    742
    midlands
    +17
    yeah thanks mate i went round my sis who got one chipped aswell and it played rce ok so i think im ok
    thanks all for the input
