Will my current speakers work with RX-V357?
sleepyone
I'm pretty much at a loss regarding speakers and what all the watt and oms mean.
I'm looking at purchasing the RX-V357 to plug my pana hard disk recorder and upcoming xbox 360 for the component and optical inputs.
I have set of yamaha speakers called NS-P210 will these be ok with this amp?
Thanks All
Dfour
They should be fine.
What is your reciever budget?
sleepyone
That's good to hear. My budget is max £150. This amp was around £120 in richer sounds
I havn't really had a good look at other makes as I thought the amp might make a good match with the speakers as both of them are from Yamaha.
