will most uk m/region players work in germany with a german telly
T
Trogster
Just a quick query, i need to buy a dvd player probably the latest cheap all conquering toshiba model in multi region format to use in the uk for a few months and than take out to Germany to use on a cheap german portable telly , will I have any problems
Thanks in advance
Cable Monkey
They will work via scart and Germany are 230v, as are we. You will need a plug adaptor but it will be no problem.
T
Trogster
Thanks very much to you both for your help, much appreciated.
