Will M&K S-150s blow up my Yam Z9!?!
Ru55
ARRRRGH! Someone please help!
Iv finally decided that M&K 150s are going to my new Front left, right and center!
Iv listened to them but the hifi store didn’t have my amp (Yamaha DSPZ9) so I had to listen to them on a different amp! :eek:
But iv been assured my Z9 will do them justice, though feel im only being told this as they want the sale! My Z9 is rated at 6 - 8ohms and the M&Ks are 4ohms and I hear are very thirsty for power!
I spoke to Yamaha technical today and his words were:
'SHOULD BE OK'
Errrrr, ok! Doesn’t fill me with confidence!!!
Has anyone used the M&K S-150s with a Yamaha Z9 or similar ohm rated amp???
Will they sound better being used on an amp with the correct ohm rating!?!
Pls help guys!! :lease:
Jase
The Z9 is THX Ultra 2 certified so will be fine with the M&K's. To pass this certification it has to be capable of driving speakers with impedance loads down to 3.2 Ohms. :)
Yes, they do like power but the Flagship Amps like the Z9, Denon A1SRA etc will all run them well.
Ru55
OWwwwwwwwwww!! Good news!!!
Thanks for ya reply Jase
30CenturyMan
I wouldn't rule out adding a power amp at some point. Passive M&Ks love power.
Benefits of more power will include smoother sound and increased dynamics. :)
Ru55
The 150s would have to impress with my Z9 alone, cus if I buy them im not going to be able to afford a power amp for a long time!!
R
recruit
The S-150's are great speakers Ru55 and IMO some of the best i have heard for Home Cinema, the Z9 is a very capable amp and will have no problems running them.. :thumbsup:
Ru55
Cheers recruit
Your kit list is mind blowing mate!! Did you sell your wife and kids!?!
R
recruit
Thanks Ru55 - Fortunately i do not have a wife and kids !
I did used to have a Z9 though and loved it, great amp :smashin:
JohnnyScot
Russ,
Hopefully my list of kit below will answer your question!
I really struggle to run my Z9 at a volume higher than about -10dB for any sustained period of time, just too loud! So the Z9 had ample headroom left when driving the 150s.
Enjoy - I know I do.
John
cliveuk
hi RU55, i have a yamaha RXV-1500 connected to a pair of dynaudio audience 52`s and they are 4ohm and it drives them without any problem at all.
i had the same problem i spoke to yamaha and they said it would be ok just to make sure i selected the lowest setting on the amp which is 6ohms
Ru55
Cheers guys!
Cliveuk, when I spoke to Yamaha they told me to leave my amp on 8ohm setting!?! :confused:
JohnnyScot Ya put my little mind at ease!!! Great kit list bet you didn't have to sell your wife and kids like recruit though! :)
Cant wait to get me 150's now, goin to try n' distract the staff with a shiny suite and run out the store with one of their M&K subs! I hear there heavy, so my plan might not pan out! :thumbsdow
cliveuk
well i was told to set it to the lowest setting by yamaha :rolleyes:
this makes sence i suppose because the amp is driving 4 ohm speakers so i guess it would find it easier if set to 6ohm, id double check with yamaha or maybe someone here can offer some help
