Will it work?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by INchSHOrT, Oct 6, 2004.
  1. INchSHOrT
    INchSHOrT
    Sep 29, 2004
    115
    16
    Hi I have acquired a sky digital box, will this work off the old round satellite dishes, if not, is the direction of the new oval satellite dishes same as the previous round ones?
    Cheers,
    Inchshort
  2. Techno Freak
    Techno Freak
    Aug 24, 2003
    312
    16
    North-East
    I would have thought not, but don't know for sure.
    Try phoning a local independant satallite installer, see if they know.
  3. nigels0
    nigels0
    Sep 7, 2004
    42
    It should work - but you will have to shift the dish from pointing at Astra 1 (19.2E) to Astra 2 (28.2E) - this is of course assuming that the round dish you are talking about was used to receive Sky when it was analog.
  4. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    Bradford, West Yorkshire.
    +324
    Of course it will work! As long as the LNB is compatible, you'll be fine.
    However, if the LNB is from an old analogue system it's highly unlikely it will be. The later ones were dual band and will work with your newly acquired digibox. Try it, you can't do any damage.
    The dish will need realigning to 28.2E as Nigels0 says.
    A. Dork
  5. INchSHOrT
    INchSHOrT
    Sep 29, 2004
    115
    16
    thanks for the reply guys, gonna test it out on sunday.
    They way I intend on testing it out, will be to take the reciever and telly up onto the roof, via an extension cable, and then adjust thje position of the dish until it finds a channel, what dya guys think, or is there an easier route that won't cost anything.
  6. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    +324
    Remember Rod Hull? :suicide:
    A. Dork
  7. INchSHOrT
    INchSHOrT
    Sep 29, 2004
    115
    16
    Nope, care to elaborate?
  8. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    +324
    Rod Hull & Emu? :)
    Poor bugger died when he fell off the roof adjusting his TV aerial.
    Rather you than me mate! :eek:
  9. INchSHOrT
    INchSHOrT
    Sep 29, 2004
    115
    16
    nah m8, i wouldn't try anything too dratic, my sky can be raeched at working height when stood on a flat roof....
