Will It Work Abroad
Discussion in 'LCD & LED LCD TVs' started by Anmarube, Aug 10, 2005.
  1. Anmarube
    Anmarube
    Aug 7, 2005
    Will my Samsung LCD work in Cyprus?.I know they use the same voltage but not if they use the same system.Any advice would be great.
    Russ :lease:
  2. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,213
    Glasgow, UK
    +1,310
    Cyprus is PAL B/G. UK is PAL I. You will probably be fine because these days I'd imagine the tuner will work for all PAL systems.
  3. Starfury
    Starfury
    May 5, 2005
    99
    +5
    I think the Samsung TVs have options for Auto/Pal/Secam/NTSC in the tuner set up, with a further setting for tuner sound BG/I/etc. So i think it should work but im not sure.
    Something to be certain of is that this is in relation to the analogue tuner, if its got inbuilt freeview, then the Digi TV part probably wont pick up a signal.
